Test UR30 .30
Pierrick
Point(s): 565
PostPosted: Sun 5 Feb 2012, 03:59 pm    Post subject: Test UR30 .30 Reply with quote
Bjr,
pour ceux que ça intéresse, une version de test de la .30 est dispo sur le site de travail : http://uracer.freeforums.org/index.php
News à découvrir :
RMS:
- tournaments are now replaced by "Race events", and Races by "Heats"
- team management: the race event setup allows to select drivers and slot cars, and group them into teams
- UR30 manages now starting positions. There is one starting pos per lane in an analogue circuit, one or more starting pos per lane in a digital circuit
- the race event setup (previously tournaments) are not configured in text files anymore. A dedicated screen allows to setup race event (race event setting screen)
- a race event is splitted into one or more heats
- staggered races are replaced by race events, staggered option is now called Round Robin in race event settings
- the round robin rotations can be changed on the race event setting screen
- UR30 sound manager speaks now. Driver names or starting position can be told when a heat starts
- hardware setup: hardware device tree view replaced by a convenient drop down combo
- race event settings (including driver & slot car selection) can be stored in the database before the race event starts
- all view panes (circuits, drivers, races...) are now managed as floating toolbars
- race event toolbar is managed now. It allows to display heat events while racing
- new toolbar driver heat status displays on going heat driver status
- this toolbar allows to change team driver during a heat
- coast time managed
- realistic finish option allows to end heats like in real life races
- automatic heat switch managed (second counter can be setup)
- selection of racing pos allowed. Eg.: a race event can be setup only on 3 lanes over 4 on a 4 lane circuit
- staggered races replaced by round robin race events => the starting lights are now managed when drivers change lanes
- new sounds managed: deslot sound, heat description (spoken)
- race event heat display enhanced: new driver/heat grid + new lane (starting pos)/heat grid
- new scores managed: deslots (penalty or bonus), false starts and reaction time
Track Layout Editor:
- new objects: arrows, curves
- export in DXF format
- 3D camera toolbar
La version en cours de test est la 30a3. Le périmètre va encore légèrement évoluer, et l'écran de paramétrage des tournois va être modifié suite aux retours des premiers testeurs.
Cdlt,
/P.
PostPosted: Sun 5 Feb 2012, 03:59 pm    Post subject: Publicité
Point(s): 13,658
PostPosted: Sun 5 Feb 2012, 04:53 pm    Post subject: Re: Test UR30 .30 Reply with quote
Je teste ça très vite et te fais un retour Okay
Pierrick
Point(s): 565
PostPosted: Sun 5 Feb 2012, 05:42 pm    Post subject: Test UR30 .30 Reply with quote
partager le résultat des tests sur le forum de travail Wink Okay Okay
Point(s): 13,658
PostPosted: Mon 6 Feb 2012, 01:30 pm    Post subject: Test UR30 .30 Reply with quote
Bon, les tests ont tourné très court car cette version plante au démarrage sur le PC de ma piste Sad
Voici le contenu du fichier de log :
Code:
020612 12:33:49|16 Message log started
020612 12:33:49|0 Revision 3.0.30a3-Feb 5th, 2012
020612 12:33:49|31 Direct Input setup OK
020612 12:33:49|0 Start version investigation check
020612 12:33:49|0 System version detection : 2-5
020612 12:33:49|0 System version : 2
020612 12:33:49|0 IO Opendriver result : 324
020612 12:33:49|0 IO Inp32 result : 1 - addr : 888
020612 12:33:49|0 Hardware initialized
Par contre, j'ai pu la lancer sans problème sur un autre PC ... lequel n'est pas raccordé à la piste RollingEyes
Point(s): 13,658
PostPosted: Tue 7 Feb 2012, 11:11 am    Post subject: Test UR30 .30 Reply with quote
Pour info, sur le PC non relié à la piste j'ai tout de même fait quelques tests au clavier hier soir en mode "Quick heat" : tout semble fonctionner comme je l'attendais Okay
Par contre, il manque (ou je n'ai pas trouvé) un moyen pour permettre de finir un segment dans le cas où il y ait des abandons ou des non partants.
Il faudrait pour ça un bouton en complément des boutons "HeaderSuspend" et "HeaderGoStop" ; si ce bouton n'est actif qu'au delà du temps défini pour le segment, c'est encore mieux Wink
Côté résultat attendu, sur la base d'un segment de 5 minutes lors duquel un pilote abandonne après 8 tours le résultat serait de 8 tours en 05:00 ; de même, le résultat pour un éventuel non partant serait de 0 tour en 05:00
Quoi qu'il en soit, j'ai hâte de pouvoir l'essayer en conditions réelles Cool
Pour info, bien que ne l'utilisant généralement pas, j'ai aussi voulu essayer le mode "Race event" mais sans réussir à générer les segments tels que je les attendais ; de plus, je crains d'avoir au passage foutu le bazar dans les "Race event setting" proposée RollingEyes
Pourtant je voulais juste paramétrer une course où les pilotes roulent avec leurs autos respectives sur toutes les voies selon l'ordre de rotation traditionnel (1-3-4-2 par exemple pour une 4 voies)
Heu, par contre je ne suis vraiment pas sûr de réussir à formuler tout ça dans un anglais compréhensible pour faire avancer le schmilblick sur http://uracer.freeforums.org/index.php ...
Pierrick
Point(s): 565
PostPosted: Sat 11 Feb 2012, 01:00 am    Post subject: Test UR30 .30 Reply with quote
Bonjour Fred,
pas de pbs pour l'anglais... Interviens en français sur le forum, il y a aussi des francophones.
Je préfère tout centraliser sinon on ne va pas y arriver !
En te remerciant,
/P.
