1967 Indy Turbine
Goto page: 1, 2, 3, 4, 5  >
Jairus Watson
Point(s): 118
PostPosted: Wed 30 Dec 2009, 01:30 am    Post subject: 1967 Indy Turbine Reply with quote
Driven by Parnelli Jones during the 200 mile race (500 miles) at The Brickyard (Indy), Car #40 lead 171 laps. On the 197th lap, it suffered a gear box failure ($6.00 part) and eventually finished sixth. What might have made a huge impact on automobiles had the gas turbine-driven car actually won the race? The next year, "the powers that be" changed the rules to make the use of the gas turbine untenable in INDY car racing although they tried again with the Lotus 56 "Wedge".
I was asked to build this example using one of John Havlicek's beautiful re-wound 26D motors. For a while I hesitated and balked at the idea of building a chassis with 4-wheel drive... but upon discovering a few drawings done by Steve O'Keefe over at Scratchbuilt.com sealed the deal.
All bearings will be sealed ball races including the idler between the motor and the central drive shaft. Gear ratio will be 4.125 to 1, but can be adjusted later if need be.
The chassis is to be constructed from brass rod as much as possible as if the car were constructed in 1967-68. Have not decided on the paint yet... Smile
Hope this one goes fast as I promised Bosmeck that I would start on his Honda F1 after the 1st.... nasvrodié
Jairus Watson
PostPosted: Wed 30 Dec 2009, 01:30 am    Post subject: Publicité
Jairus Watson
Point(s): 118
PostPosted: Wed 30 Dec 2009, 05:13 am    Post subject: 1967 Indy Turbine Reply with quote
Le concept de technologie de la conduite d'un arbre le long de l'axe du moteur est le défi ici et l'utilisation d'un dispositif de tendeur est ce que j'ai choisi. Le support moteur est une pièce en acier vintage que j'ai découpé et a ajouté quelques tube de laiton et tige de renforcer afin de maintenir maillage de vitesses en douceur et de calme. L'engin a un tendeur 0.125 "diamètre de l'arbre est tellement parfait pour une courte section de l'essieu. Paliers d'essieu sont utilisés dans les morceaux de tubes de production et l'oisif tourne bien quand il est lancé sur le pouvoir banc. Engins de bruit de fond très peu!
The engineering concept of driving a shaft running along the axis of the motor is the challenge here and the use of an idler gear is what I chose. The motor bracket is a vintage steel piece that I cut up and added some brass tube and rod to strengthen in order to keep gear mesh smooth and quiet. The idler gear has a 0.125" shaft diameter so is perfect for a short section of axle. Axle bearings are used in the pieces of tubing and the idler spins nicely when run on bench power. Very little gear noise!
Beaucoup d'espace pour les 0.938 "arbre d'entraînement et les engins de maintenant.
Plenty of clearance for the 0.938" drive shaft and gear now.
En avant et vers le haut!
Onward and upward! Cool
Jairus Watson
Point(s): 2,072
PostPosted: Wed 30 Dec 2009, 10:15 am    Post subject: 1967 Indy Turbine Reply with quote
Okay une superbe réalisation "in live" sur Folm
Merci Jairus
La carrosserie est une lancer?
PostPosted: Wed 30 Dec 2009, 10:49 am    Post subject: 1967 Indy Turbine Reply with quote
Jairus Watson wrote:
Shocked nasvrodié
Arno
Point(s): 4,012
PostPosted: Wed 30 Dec 2009, 10:57 am    Post subject: 1967 Indy Turbine Reply with quote
Faut absolument que je trouve des coques comme ca RollingEyes
PostPosted: Wed 30 Dec 2009, 11:01 am    Post subject: 1967 Indy Turbine Reply with quote
Tu veux faire du Lexan ou c'est la forme de cette voiture ce VTM à turbine qui t'inspire ?
Arno
Point(s): 4,012
PostPosted: Wed 30 Dec 2009, 11:03 am    Post subject: 1967 Indy Turbine Reply with quote
Les deux Mr Green Je veux faire du lexan pour habiller certain chassis, et la forme m'inspire bien Mr Green
PostPosted: Wed 30 Dec 2009, 11:13 am    Post subject: 1967 Indy Turbine Reply with quote
Tout ce que j'aime, ça pourrait même être écrit en Chinois que ça ne me gênerais pas... Okay
PostPosted: Wed 30 Dec 2009, 11:17 am    Post subject: 1967 Indy Turbine Reply with quote
Là je suis d'accord frère !
Et puis nos amis anglo-saxons font au moins l'effort d'utiliser un traducteur automatique pour ceux qui ne parlent pas le J.C. Van Dame ...
Point(s): 11,871
PostPosted: Wed 30 Dec 2009, 11:34 am    Post subject: 1967 Indy Turbine Reply with quote
Point(s): 11,871
PostPosted: Wed 30 Dec 2009, 11:37 am    Post subject: 1967 Indy Turbine Reply with quote
Arno, MP...
Point(s): 27,683
PostPosted: Wed 30 Dec 2009, 12:01 pm    Post subject: 1967 Indy Turbine Reply with quote
J'imaginais même pas que ça pouvait exister une chOse pareille ... pfff ..... Shocked
Ils sont forts ces chinois ! Mr Green
Arno
Point(s): 4,012
PostPosted: Wed 30 Dec 2009, 02:55 pm    Post subject: 1967 Indy Turbine Reply with quote
1500GP wrote:
Arno, MP...
re
Defray
PostPosted: Wed 30 Dec 2009, 03:03 pm    Post subject: Re: 1967 Indy Turbine Reply with quote
Indy Turbine
Certainement,les deux plus belles paroles de la langue Chinoise... Okay
Jairus Watson
Point(s): 118
PostPosted: Wed 30 Dec 2009, 07:32 pm    Post subject: 1967 Indy Turbine Reply with quote
Bon, en dehors de construction du moteur et des engins de fainéant ... nous avons maintenant un arbre d'entraînement montures!
Okay, building outwards from the motor and idler gear... we now a drive shaft mounts!
Avec un équipement installé les engins de spin en douceur avec un minimum de bruit. Next up sont les essieux et dans le reste du châssis.
With equipment installed the gears spin smoothly with a minimum of noise. Next up are the axles and the rest of the chassis.
Cool
Jairus Watson
Page 1 of 5
